LRP : Vector X20 Modified BL Motorlar
Tarafından,
30-01-2012 Tarihinde 07:03
LRP, Vector X20 adini verdigi modifiyeli 4.5, 5.5, 6.5, 7.5, 8.5 ve 9.5Turnluk modifiyeli motorlarinin tanitimini yapti.
LRP X20 Modified Brushless Motors |
The new LRP Vector X20 modified brushless series is a high-end motor line developed completely from scratch. It’s technology is trend-setting. LRP’s R&D department had highest efficiency and maximum power in mind, when they designed these new high-performance motors. The result speaks for itself: more power and higher rating at improved temperature characteristics and lowest friction. A novelty of the new technology is the dual axis balanced 12.5mm sintered worksteam rotor resulting in an absolutely precise running and increased efficiency. The larger sized ball bearings and LRP’s PreciSensor™ system also contribute to the impressive performance of the new LRP Vector X20 motors.
The ultra lightweight, precision machined 7075-T6 aluminium housing has optimised cut-outs for best heat absorption and lowest running temperatures also at full power output.
Alintidir : SMD |
