• RC-LIGHTS DELUXBRAKE™ 14 LED Controller
      Directly power up to 14 LEDs. Current limiting resistors are built right in. Using the DELUXBRAKE™ 14 LED Controller, LEDs can be directly powered from the throttle channel of the RX using the included RX Pass-Thru™ (mini Y-harness).
      Dual intensity brake light action is built right in! Throttle channel input fully reversible.
      LEDs are split into five banks: 4 constant/strobing headlights (2 each side R & L; headlight strobe rate fully-adjustable); 4 auxiliary lights switchable from TX/RX auxiliary channel input in multi-mode; 4 switched dim or full bright depending on throttle stick position (GAS or BRAKE); and 2 fully-adjustable intensity fog lights switched from TX/RX auxiliary channel input in multi-mode.
      Auxiliary channel input can be used for simple power on/off to the entire controller or multi-mode can be enabled. If enabled the lights will default to all off, flip the TX switch once and the headlights and brake lights will turn on, flip it a second time and everything will turn off, flip it again and the headlights and brake lights will turn on with the auxiliary and fog lights, and flip it once more and everything will turn off.
      The DELUXBRAKE™ 14 LED Controller is a perfect combination of our popular RPS & EBS electronic control switches (remote power and electronic brake switches).
      Throttle and auxiliary center-stick auto-detect for precise lighting effects every time.
      Full-feature functionality built right in: headlight strobes, multi-action auxiliary lighting switching, adjustable intensity fog lights, and dual intensity brake lights for the ultimate in scale lighting effects for any R/C vehicle.
      Bundled with these complete systems: #5034, #114
      #5034: Is a universal LED system that can be installed in any 1:16 to 1:8 size Radio Control Car or Truck with accessible throttle servo or ESC plug and optional available auxiliary channel. Everything needed for a complete installation is included with every system. 4 white headlights, 4 white auxiliary lights, 2 blue fog lights, and 4 red dual-intensity electronic brake lights are all included.
      #114: Is a LED system designed for use with RPM Light Canisters. This system will light the 4 LED front bumper or 4 LED narrow roof bar, 6 LED wide roof bar, provide dual intensity brake light action for the 2 LED tail lights, and add optional blue and amber tail lights. Everything needed for a complete installation is included with every system.
      Source : RC-lights
      Bu makale başlangıçta forumdaki konuda yayımlandı: RC-LIGHTS DELUXBRAKE™ 14 LED Controller başlatan yazar MSenturk Orijinal mesajı görüntüle
