• VP PRO power switch
      VPPRO power switch is a tiny MCU controlled on/off switch for your radio controlled model. A simple pish button operates the switch meaning to eliminate teh problems associated with intermittent contac of an ordinary meachanical switch.The sealed unit is plastic and can easily be mounted to the transponder mount of your model or anywhere else you can mount it using double side tape.The switch also features a LiPo mode.by turning this on the switch unit will auto detect low LiPo voltage and cut off power to protect your LiPo from over dis-charging. This of course can be turn off if you have other safeguards in place or using NiMH/NiCad battery.
      Source : Neobuggy
      Bu makale başlangıçta forumdaki konuda yayımlandı: VP PRO power switch başlatan yazar MSenturk Orijinal mesajı görüntüle
