• TrakPower charger and brushless system
      At the Hobbico booth the US company have the TrakPower VR-1 charger and DPS 25A switched power supply on show. The multiple output charger offers a 20A as well as 6A output, dual balancer, programmable battery memory function, back-lit display and a Mini USB port for firmware upgrades. The charger is designed to dock right into the DPS 12V 25A switched power supply to reduce wiring on your pit table and work bench. The power supply features multiple outputs and an LED indicator to monitor power load.
      Also on show at the Hobbico stand is the TrakPower MS sensored brushless system consisting of the MS-1 BL speed controller and the MS series brushless motors. The ESC features an all-aluminium case, stock and modified profiles including zero timing 'blinky' mode setting and potent hardware for motors down to 2.5T. The MS motors come with a CNC-machined aluminium can, adjustable timing and in several windings from 6.5T modified up to 21.5T stock.
      Source: Area 52
      Bu makale başlangıçta forumdaki konuda yayımlandı: TrakPower charger and brushless system başlatan yazar MSenturk Orijinal mesajı görüntüle
