• Active Hobby Fiber Optics LED Lights
      Active-Hobby will be releasing Fiber Optic LED Lights. They can be arrainged in various applications be arranged in various applications and high-mount stop light LED position line, Gatling headlights etc., depending on the idea. Light is a set of two optical fibers and resin cup of 1m length 1mm diameter holes in seven no light leakage is provided. (5mmLED not included) fiber optic cable that comes with has adopted a soft flex type and amount of light which is excellent in workability. ※ 1m fiber optic cable that is included in the product, you will need assembly work like users to cut to desired length, attached to the unit.※ is required, such as drilling, machining small to mount the same unit.
      Source : D2yankidori
      Bu makale başlangıçta forumdaki konuda yayımlandı: Active Hobby Fiber Optics LED Lights başlatan yazar MSenturk Orijinal mesajı görüntüle
