After releasing the VX 540-size electric brushless motors Reds Racing now introduce a dedicated series for 1/8th scale racing. The V8 are specifically designed 1/8th off-road motors to provide exceptional power, superior smoothness and control in combination with high efficiency and a low temperature operation. Coming with a highly finned CNC-machined aluminium can for improved heat dissipation the motor is capable of both sensored and sensorless operation and available in two KV options of 1900KV and 2100KV.
Features:
– CNC-machined 6061 T6 Billet aluminium ribbed heatsink can
– High-strength balanced 4-Pole Neodymium sintered rotor
– Low Resistance, High Power, Silver-plated Solder Tabs
– High Purity Copper Windings
– High RPM precision ball bearing for maximum performance and life cycle
– Sensored and sensorless operation
– Dual-plug sensor wire harness
Specifications:
– Maximum input voltage: 22.2V/6S LiPo
– Diameter: 42mm
– Length: 69mm
– Shaft Diameter: 5mm
– Shaft Length: 18mm
– Weight: 320g
Kaynak : redrc.net
