• SkyRC Motor Analyser brushless motor tester
      New from SkyRC comes the Motor Analyser, a device to test and fine-tune electric brushless motors. The motor tester offers KV measurement, voltage, RPM and Amp draw tests as well as timing and hall sensor checks together with a noise level test that allows to draw conclusions on the conditions of the ball bearings. Coming in a sturdy aluminium case the device sports a back-lit display, jog dial menu operation and it includes an array of wires such as a sensor cable, motor connection wires and power input adapters.
      Specifications:
      – Dimensions: 136.5×80.6×24.5mm
      – Weight: 282g
      – Input voltage: 7.4-8.4V
      – Screen: Backlit LCD
      – Motor timing range: 0-70°
      – Noise level measurement: 60-120dB
      – Supported motors: sensor and sensorless 2-36 poles
      Kaynak : redrc.net
      Bu makale başlangıçta forumdaki konuda yayımlandı: SkyRC Motor Analyser brushless motor tester başlatan yazar 100kmh2sn Orijinal mesajı görüntüle
