• GForce Mini Break-in system
      GForce introduce the Mini Break-in system for mini and micro-size brushed motors. Designed for the use with Tamiya’s Mini 4WD series of “slot cars”, the system is also usable for the brushed motors found in Kyosho’s Mini-Z or HPI’s Micro RS4 line of vehicles. The motor run-in system is housed in a sturdy case with a jog dial to adjust the output voltage and also a timer that stops the run-in process after a certain time. A non-slip foam pad and a velcro strap prevent the chassis or motor from moving around and the break-in device is powered by four AA-size batteries or an optional power supply.Specifications:
      – Dimensions: 112x47x45mm
      – Input: 4.8V-6.0V
      – Output: 0.1V-6.0V
      – Timer for run-in function
      – LCD display
      – Jog dial for menu operation
      – Pre-wired with crocodile clamps
      Kaynak : redrc.net
      Bu makale başlangıçta forumdaki konuda yayımlandı: GForce Mini Break-in system başlatan yazar 100kmh2sn Orijinal mesajı görüntüle
