• Ally Garage
  • ProTek R/C Blue Flame engine heater
    New from ProTek R/C comes the Blue Flame engine heater to effectively pre-heat the critical internal parts of a nitro engine. Pre-heating the engine head and the upper parts of the crankcase results in significantly reduced wear and unnecessary stress when compared to cold starting. The engine’s crankshaft, connecting rod, piston and sleeve all benefit and will last much longer when pre-heated regularly plus the engine’s “pinch” will be reduced which can be beneficial especially for new or rebuild engines. An access port atop the device allows to easily start the engine and monitor temperatures while in use. As a safety measure, a 10-minute timer shuts off the heater automatically. The heater comes pre-wired with a T-type connector and includes a crocodile clamp adapter wire.
    Features:
    – 10-minute safety timer turns heater off automatically
    – LED indicates status of the engine heater
    – 12V DC power source compatible with voltage cutoff
    – 3S 11.1V LiPo battery compatible
    – Access port allows you to start and monitor your engine temperature without removing the heater
    – Built-in temperature sensor to control heater power output
    – Fire and heat-resistant adjustable cover
    – Fits all .19 – .26 nitro engines
    – Small, lightweight and compact for quick and easy storage
    – High-efficiency heat transfer design
    Kaynak : redrc.net
    Bu makale başlangıçta forumdaki konuda yayımlandı: ProTek R/C Blue Flame engine heater başlatan yazar 100kmh2sn Orijinal mesajı görüntüle
